[postgis-users] Merge all polygons from a dataset
Obe, Regina
robe.dnd at cityofboston.gov
Mon Aug 4 03:25:23 PDT 2008
Try the trick documented here
http://postgis.refractions.net/documentation/manual-svn/ST_Collect.html
On hindsight - I realized the ST_Multi call here is probably unnecessary
so you can leave that part out.
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
danny
Sent: Monday, August 04, 2008 5:04 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Merge all polygons from a dataset
I'm getting very long processing time from ST_Union (on a shape of
europe at 1/100000 it's been running since 2 hours and hasn't finished
yet; on my previous one of 1/1000000 it took ~1 hour)
Any other alternative and quicker ways to accomplish the same operation?
I just executed st_buffer(st_collect(the_geom)) but still waiting.
Should it take as long? ST_Collect by itself executes fast but it's
result violates the geometry check constraint.
On Fri, Aug 1, 2008 at 5:31 PM, danny <whatevar89 at gmail.com> wrote:
Thanks Robert.
I actually exported from ogr2ogr and it created a shape that
worked fine in ArcView.
Best
On Fri, Aug 1, 2008 at 5:19 PM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
Could ArcView perhaps want some columns other than just
the shape? Perhaps you could put a numeric ID or something else in
there.
Just a thought,
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
danny
Sent: Friday, August 01, 2008 9:30 AM
dataset
Many thanks, Regina! Indeed ST_Union generated the
polygon, invisible in PgAdmin!!
It creates a nice layer when I open it in uDig.
However when I export it with pgsql2shp, the shape is
unreadable by ArcView with the errmsg: Number of shapes does not match
the number of table records.
Here's how I created the layer:
create table europe_contour();
SELECT addgeometrycolumn('db, 'europe_contour',
'the_geom', 32767,'MULTIPOLYGON', 2 );
insert into europe_contour(the_geom) values( (select
st_union(the_geom) from europe));
Then I generate the shapefile:
"c:\Program Files\PostgreSQL\8.3\bin\pgsql2shp.exe" -u
postgres -P password -f europe_contour db europe_contour
Any suggestions perhaps on anything I've wrong?
On Fri, Aug 1, 2008 at 1:15 PM, Obe, Regina
<robe.dnd at cityofboston.gov> wrote:
Erik,
How were you using ST_Union and what exactly do you mean
by no result. no result as it looks blank? If you are using something
like PgAdmin III - it will look blank because it exceeds the buffer
supported by PgAdmin III.
SELECT the_geom is null
FROM (somequery or table) as foo
LIMIT 1
will tell you if its actually returning no geometry
Hope that helps,
Regina
danny
Sent: Friday, August 01, 2008 6:12 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Merge all polygons from a
dataset
Hello everybody,
I've converted a shapefile of Europe to PostGIS. I would
like to merge all the countries together so that I only have one polygon
left, the whole contour of Europe. I have tried ST_Union that gives me
no result. I've tried several other functions to no avail. Does anybody
know how I should proceed?
Many thanks,
Erik
The substance of this message, including any
attachments, may be confidential, legally privileged and/or exempt from
disclosure pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender and
delete the material from any computer.
Help make the earth a greener place. If at all possible
resist printing this email and join us in saving paper.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080804/ee9068f0/attachment.html>
