[postgis-users] problem to transform coordinates
Obe, Regina robe.dnd at cityofboston.gov
Mon Aug 4 08:26:53 PDT 2008
I get the same wrong answer so your install is fine.
I don't think your coordinates are in 22523.  They seem to be truncated
and flipped.
For example
Select ST_AsText(ST_Transform(ST_GeomFromText('POINT(-45
-20.65)',4326),22523 ))
Gives me
POINT(500024.031982543 7716597.82168034)
So its like your coordinates are flipped and then divided by 1000 or
something
Assuming that is what is happening - then your point should be
- POINT(500290 7650676)
SELECT ST_AsText(ST_Transform(ST_GeomFromText('POINT(500290
7650676)',22523), 4326))
Which would give me
POINT(-44.9974366430774 -21.2456507664743)
Is that more like what you were expecting for an answer?
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Felipe Fedel Pinto
Sent: Monday, August 04, 2008 10:49 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] problem to transform coordinates
SELECT ST_AsText(coord_22523)
FROM coordsformiga limit 2;
return:
        st_astext
 POINT(7650.676 500.29)
 POINT(7624.401 592.751)
(2 rows)
SELECT ST_AsText(ST_Transform(coord_
	22523, 4326))
return:
                 st_astext
 POINT(140.139757378998 -89.9975973774248)
(2 rows)
SELECT postgis_full_version();
 POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS
(1 row)
On Mon, Aug 4, 2008 at 10:20 AM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
	Felipe Fedel,
	Can you send a sample of your data - results of the 2 queries
below
	-- and result you get when you do
	SELECT ST_AsText(ST_Transform(coord_22523, 4326))
	Also what does
	give
	Only thought I have that could be wrong is your coordinates are
not
	really 22523 or there is a problem with your proj 4 install. The
above
	queries should pinpoint that.
	Hope that helps,
	Regina
Of
	Felipe Fedel Pinto
	Sent: Monday, August 04, 2008 9:27 AM
	it also happens when I use ST_Transform and return the same
thing from
	SELECT proj4text FROM spatial_ref_sys WHERE srid = 22523;
	Do you have another idea??
	Thanks!!!!
	Felipe Fedel
	On Thu, Jul 31, 2008 at 1:13 AM, Paragon Corporation
<lr at pcorp.us>
	wrote:
	       Maybe there is something wrong with your entry in the
	spatial_ref_sys table for that SRID.  Also provide two sample
22523
	points and what the ST_Transform looks like.
	       Also please use ST_Transform if you are using a PostGIS
install
	> 1.2
	       What does
	       SELECT proj4text
	       WHERE srid = 22523
	       give you?
	       Mine gives
	       +proj=utm +zone=23 +south +ellps=intl
	+towgs84=-206,172,-6,0,0,0,0 +units=m +no_defs
	       Hope that helps,
	       Regina
Of
	Felipe Fedel Pinto
	       Sent: Wednesday, July 30, 2008 7:26 PM
	       To: postgis-users at postgis.refractions.net
	       Subject: [postgis-users] problem to transform coordinates
	       To transform coordinates in PostGis I use the followed
function:
	       UPDATE <table> SET <new_geometry_column> =
	transform(<original_geometry_column>,<new_SRID>);
	       I have been having a weird problem when I try to
transform
	coordinates that are in a SRID=22523.
	       Ex: I have to transform them to a SRID=4326
	       UPDATE coordsformiga SET coord_4326 =
	transform(coord_22523,4326);
	       where coordsformiga is the table,
	                 coord_22523 is the original geometry column
with the
	coordinates in a SRID=22523
	                 coord_4326 I'd be the geometry column with the
	coordinates transformed in a SRID=4326
	       the problem is:
	       After the function, in the geometry column (coord_4326),
all of
	the 97 coordinates have the same values.
	       But it's happening only with a SRID=22523.
	       Anybody knows what is happening??
	       thanks
	       postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
	The substance of this message, including any attachments, may be
	confidential, legally privileged and/or exempt from disclosure
	pursuant to Massachusetts law. It is intended
	solely for the addressee. If you received this in error, please
	contact the sender and delete the material from any computer.
