[postgis-users] problem to transform coordinates
Felipe Fedel Pinto
fedelfelipe at gmail.com
Mon Aug 4 07:48:42 PDT 2008
SELECT ST_AsText(coord_22523)
FROM coordsformiga limit 2;
return:
st_astext
POINT(7650.676 500.29)
POINT(7624.401 592.751)
(2 rows)
SELECT ST_AsText(ST_Transform(coord_
> 22523, 4326))
return:
st_astext
POINT(140.139757378998 -89.9975973774248)
(2 rows)
SELECT postgis_full_version();
POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS
(1 row)
On Mon, Aug 4, 2008 at 10:20 AM, Obe, Regina <robe.dnd at cityofboston.gov>wrote:
> Felipe Fedel,
> Can you send a sample of your data - results of the 2 queries below
> -- and result you get when you do
> SELECT ST_AsText(ST_Transform(coord_22523, 4326))
> Also what does
> give
> Only thought I have that could be wrong is your coordinates are not
> really 22523 or there is a problem with your proj 4 install. The above
> queries should pinpoint that.
> Hope that helps,
> Regina
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Felipe Fedel Pinto
> Sent: Monday, August 04, 2008 9:27 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] problem to transform coordinates
> it also happens when I use ST_Transform and return the same thing from
> SELECT proj4text FROM spatial_ref_sys WHERE srid = 22523;
> Do you have another idea??
> Thanks!!!!
> Felipe Fedel
> On Thu, Jul 31, 2008 at 1:13 AM, Paragon Corporation <lr at pcorp.us>
> wrote:
> Maybe there is something wrong with your entry in the
> spatial_ref_sys table for that SRID. Also provide two sample 22523
> points and what the ST_Transform looks like.
> Also please use ST_Transform if you are using a PostGIS install
> > 1.2
> What does
> SELECT proj4text
> WHERE srid = 22523
> give you?
> Mine gives
> +proj=utm +zone=23 +south +ellps=intl
> +towgs84=-206,172,-6,0,0,0,0 +units=m +no_defs
> Hope that helps,
> Regina
> Felipe Fedel Pinto
> Sent: Wednesday, July 30, 2008 7:26 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] problem to transform coordinates
> To transform coordinates in PostGis I use the followed function:
> UPDATE <table> SET <new_geometry_column> =
> transform(<original_geometry_column>,<new_SRID>);
> I have been having a weird problem when I try to transform
> coordinates that are in a SRID=22523.
> Ex: I have to transform them to a SRID=4326
> UPDATE coordsformiga SET coord_4326 =
> transform(coord_22523,4326);
> where coordsformiga is the table,
> coord_22523 is the original geometry column with the
> coordinates in a SRID=22523
> coord_4326 I'd be the geometry column with the
> coordinates transformed in a SRID=4326
> the problem is:
> After the function, in the geometry column (coord_4326), all of
> the 97 coordinates have the same values.
> But it's happening only with a SRID=22523.
> Anybody knows what is happening??
> thanks
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080804/dad4a851/attachment.html>
