[postgis-users] How to trim a GeometryCollection toget aMultiPolygon?
Obe, Regina
robe.dnd at cityofboston.gov
Tue Aug 5 06:31:50 PDT 2008
Arnaud,
Great idea. Yes I think that is better, less prone to error and probably faster since integer checks are faster than string checks. I'm assuming the cost of accessing the ST_Dimension is not any more (and probably less) than the cost of accessing the geometry type and both are fairly negligable.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of postgis.domain.thewild at spamgourmet.com
Sent: Tuesday, August 05, 2008 8:39 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] How to trim a GeometryCollection toget aMultiPolygon?
Obe Regina - robe.dnd at cityofboston.gov a écrit :
> WHERE ST_GeometryType(foo.the_geom) ILIKE '%polygon%'
Would it be enough to check the dimension of the geomtry in that case ?
(i.e. ST_Dimension(foo.the_geom) = 2)
And, more important, do you think it be faster than checking its type
against a string ?
Regards
Arnaud
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
