[postgis-users] Newbie Question
Pedro Doria Meunier
pdoria at netmadeira.com
Tue Aug 5 12:57:39 PDT 2008
Shame on me... I should have read Adam's question more attentively ...
Adam:
Paul is absolutely right.
Regards,
Pedro Doria Meunier
On Tue, 2008-08-05 at 12:46 -0700, Paul Ramsey wrote:
> Well, that's the opposite of the usual point-in-polygon use case
> (given an existing set of polygons and a point input, tell me what
> polygons it falls within), but it's equally tractable.
> You need an input interface, and that will be the hardest part of your
> task. You can do something in Google Maps, if you like, then stuff the
> geometry down into a script (php, asp, whatever) that in turn
> inscribes it into a SQL statement ala:
> select points.id, points.name from points where
> st_contains('POLYGON(....)', points.geometry);
> Where the 'POLYGON(...)' is constructed by your script from your user
> interface input.
> Enjoy,
> P.
> On Tue, Aug 5, 2008 at 12:24 PM, Adam Vande More <adam at imedmobility.com> wrote:
> > Hello,
> > Perhaps my questions were addressed earlier or in some documentation I
> > missed. If so, I apologize in advance as I am completely new to GIS and
> > PostGIS. Judging from the documentation I have read, my needs are extremely
> > simple vs PostGIS capabilities however I am unsure if the functionality of
> > what I want actually exists.
> > I deal with areas in the US, territories that are regional in nature but not
> > bounded by common things eg state lines, water ways, counties, etc. They
> > are irregular shapes of varying land area. I also have sets of latitude and
> > longitude points. I would like some type of system where I enter in a
> > perimeter of territories, and find out whether a particular latitude and
> > longitude point lies within that perimeter.
> > My understanding of this is that I would need to either manually create a
> > GML type file with the perimeters in it, or use some type of map authoring
> > software to accomplish this goal. Are my understandings correct and if so
> > is there a recommendation for a particular piece of software which can
> > fulfill this?
> > Also, are the libraries/functions available for determining whether a point
> > is in a perimeter?
> > Much appreciated,
> > Adam Vandemore
> > Systems Administrator
> > IMED Mobility
> > (605) 498-1610
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080805/98ad00f1/attachment.pgp>
