[postgis-users] Still cannot display postgis layers using ms4w
kreshna_iceheart at yahoo.com kreshna_iceheart at yahoo.com
Wed Aug 6 01:33:38 PDT 2008
Dear Regina....
YOU ARE CORRECT!!! I got rid of the empty FILTER clause and now the map is displayed properly! :-)
Many many many (times infinity) thanks!
-Kresh
--- On Wed, 8/6/08, Paragon Corporation <lr at pcorp.us> wrote:
> From: Paragon Corporation <lr at pcorp.us>
> Subject: RE: [postgis-users] Still cannot display postgis layers using ms4w
> To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
> Date: Wednesday, August 6, 2008, 4:10 AM
> Just a guess.  Get rid of your FILTER clause or actually put
> a where
> condition in your FILTER clause.  I think the fact that
> your FILTER clause
> is empty is causing PostgreSQL to generate an invalid query
> that looks
> something like this
> SELECT *
> FROM sometable
> WHERE
> Can't have  where without a where condition.
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of
> Sent: Wednesday, August 06, 2008 3:17 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Still cannot display postgis
> layers using ms4w
> Help. Somebody please help. Anybody. :-(
> I am using postgreSQL 8.2.5 for Windows with postGIS. The
> database was
> installed using Windows .msi installation package. I am
> also using ms4w
> 2.2.7 that comes with MapServer 5.0.2. All installed on
> Windows XP Service
> Pack 2.
> The MapServer does support postGIS. When I executed mapserv
> -v, I got the
> following:
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS
> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> In the postgreSQL database, I have created a database named
> test_mapserv. I
> also created a schema named rencana, and a table named
> kawasanbencana. The
> name of the geometry column is the_geom.
>  I have created a spatial index (kawasanbencanaspix) on the
> geometry column.
> I also use lowercase to write the 'from' statement.
> The problem is: MapServer always gives the "..Query
> error. Error executing
> POSTGIS DECLARE.." error message, no matter what I do.
> And I have tried
> everything ad nauseam.
> I have tried specifying the DATA line without USING UNIQUE
> ... USING SRID
> line. I have tried specifying the DATA line with USING
> UNIQUE ...USING SRID.
> I have tried using double apostrophe (") and single
> apostrophe ('). It
> doesn't matter. Everything I have tried has failed, and
> I still get the
> error message no matter what I did.
> My mapfiles are attached in this mail. Each reflect my
> futile attempt, and
> all of them generated the error message.
> My first attempt:
> This is my first attempt. I have both the mapfile and the
> error message
> attached on this mail.
>     CONNECTIONTYPE postgis
>     CONNECTION 'host=localhost user=rtrw
> password=123456 port=5432
> dbname=test_mapserver'
>     DATA 'the_geom from rencana.kawasanbencana'
> And I got the following error message:
> msDrawMap(): Image handling error. Failed to draw layer
> named
> 'kawasanbencana'. prepare_database(): Query error.
> Error executing POSTGIS
> DECLARE (the actual query) statement: 'DECLARE mycursor
> BINARY CURSOR FOR
> SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text
> from
> rencana.kawasanbencana WHERE () and (the_geom &&
> setSRID(
> 'BOX3D(528635.525378392 9074209,609092.162121608
> 9134520)'::BOX3D,find_srid('','rencana.kawasanbencana','the_geom')
> Postgresql reports the error as 'ERROR: syntax error at
> or near ")" LINE 1:
> ...DR'),gid::text from rencana.kawasanbencana WHERE ()
> and (the... ^ ' More
> Help: Error with POSTGIS data variable. You specified
> 'check your .map
> file'. Standard ways of specifiying are : (1)
> 'geometry_column from
> geometry_table' (2) 'geometry_column from (sub
> query) as foo using unique
> column name using SRID=srid#' Make sure you put in the
> 'using unique column
> name' and 'using SRID=#' clauses in. For more
> help, please see
> http://postgis.refractions.net/documentation/ Mappostgis.c
> - version of Jan
> 23/2004.
> My second attempt:
> I tried adding USING UNIQUE to my DATA line. There is
> something odd with my
> spatial table though: whenever I view the data contents
> with pgAdmin, I can
> always see the oid column (first column to the left, before
> the PK column).
> However, I cannot find the oid column when viewing the
> table's column
> definition. The question is: does my table have oid column
> or not? And does
> it have something to do with the error?
> Nonethless, here's my lines:
>     DATA 'the_geom from rencana.kawasanbencana using
> unique oid'
> And I still get the same error message as above. The
> difference is that the
> error message now says 'oid' instead of
> 'gid'. For instance,
> "(the_geom)),'NDR'),gid" becomes
> "(the_geom)),'NDR'),oid", but everything
> else remains the same.
> My third attempt:
> Like I said in my second attempt, I'm not sure whether
> my table has oid
> column or not. Thus, in my third attempt I used the gid
> column instead,
> especially since the gid column is my primary key column
> anyway. This is my
> lines:
> unique gid'
> And I got exactly the same error message as my first
> attempt.
> My fourth attempt:
> In my fourth attempt, I used the gid column for my unique
> id, and I am using
> SRID=1. Here is the lines:
> unique gid using
> SRID=1'
> Well I still got the error message. This time, the error
> message is slightly
> different. Instead of getting
> "::BOX3D,find_srid", I got "::BOX3D,1".
> Here is the complete error message:
> named
> BINARY CURSOR FOR
> SELECT
> from
> setSRID(
> 9134520)'::BOX3D,1) )'
> or near ")" LINE 1:
> 'check your .map
> help, please see
>  Mappostgis.c - version of Jan 23/2004.
> My fifth attempt:
> Now I had been pretty much desperate, I just wrote using
> SRID=#, closed my
> eyes, and hoped for the best. Here's the lines:
> unique gid using
> SRID=#'
> I still get an error message. This time, the error message
> is different
> altogether. Here's the message:
> named
> 'kawasanbencana'. msPOSTGISLayerParseData(): Query
> error. Error parsing
> POSTGIS data variable: You specified 'using SRID=#'
> but didnt have any
> numbers! More Help: Error with POSTGIS data variable. You
> specified
> 'the_geom from rencana.kawasanbencana using unique gid
> using SRID=#'.
> Standard ways of specifiying are : (1) 'geometry_column
> from geometry_table'
> (2) 'geometry_column from (sub query) as foo using
> unique column name using
> SRID=srid#' Make sure you put in the 'using unique
> column name' and 'using
> SRID=#' clauses in. For more help, please see
> - version of Jan
> 23/2004.
> I'm pretty much desperate. Could somebody please tell
> what's wrong on my
> mapfile? Or maybe ms4w just cannot display postGIS data? Do
> I need to
> install postGIS and MapServer on Linux, in order to get
> them work together?
> Please help. :-(
> Thanks,
> -Kresh
> postgis-users mailing list
