[postgis-users] Upload a shapefile to PostGIS via Web?
Luigi Castro Cardeles
luigi.cardeles at gmail.com
Thu Aug 14 05:17:33 PDT 2008
Hi Xian,
there is some bindings to ogr (phpogr, pyrhon etc). Maybe you should see
something.
Why you want to upload shp files direct to PostGIS via web? Is there really
need? Are you trying to make some type of WFS with this data?
Maybe is there some other solution for your problem.
[]'s
2008/8/14 Guido Lemoine <guido.lemoine at jrc.it>
> Luigi et al,
> If you use a Java environment, you would want to look at Geotools (can
> parse shapefiles to Postgis)
> and a servlet or JSP set-up for multi-part request processing on the
> server. If you are familiar with
> Groovy and Grails, I can recommend that to make the coding a lot easier.
> GL
> Xiaoyu Guan wrote:
>> Hi Luigi:
>> yes, I also see the problem, there are at least two steps, step1: zip all
>> shapefile and upload. step 2: extract zip file, and import to certain
>> database. Maybe there is one way or some people are already working on it. I
>> am think whether possible translate OGR2OGR or Shp2pgsql into python or
>> other languages, which user can runing the conversion part at server side.
>> That s what I am thinking about the solution.
>> Thanks for your reply.
>> All the best
>> Xiaoyu
>> Xiaoyu Guan (Sam)
>> Geo-information Science
>> Wageningen UR
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Guido Lemoine
> Joint Research Centre, European Commission
> Institute for the Protection and Security of the Citizen (IPSC)
> Support to External Security
> Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
> Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
> WWW: http://ses.jrc.it
> Disclaimer:
> Views expressed are those of the individual and do not represent the views
> of the European Commission
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080814/957c06da/attachment.html>
