[postgis-users] 3d buffer
Sufficool, Stanley
ssufficool at rov.sbcounty.gov
Fri Aug 15 08:33:50 PDT 2008
Step 1: Get center of cube by averaging all points (x,y,z) on the cube
Step 2: Get the delta of each points (x,y,z) from the center point and
divide by distance from the center and then add/subtract that delta from
the points (x,y,z) multiplied by the buffer number
This would expand the CUBE from the center by the given amount.
Someone correct this if needed since I have absolutely no practical
application or data to drive this code.
VERY PSEUDO CODE (since there is no cube geometry type?):
CREATE FUNCTION st_buffercube(theCube geometry, buffer double precision)
returns geometry AS $BODY$
declare i int;
/* Centroid of cube */
declare cx double precision;
declare cy double precision;
declare cz double precision;
/* Cube point */
declare px double precision;
declare py double precision;
declare pz double precision;
/* Cube point delta */
declare segLength double precision;
declare dx double precision;
declare dy double precision;
declare dz double precision;
/* Output ?CUBE? */
declare retWKT character varying(4096);
BEGIN
cx := 0;
cy := 0;
cz := 0;
for i IN 1..st_npoints(theCube) LOOP
cx := cx + st_x(pointn(theCube,i));
cy := cy + st_y(pointn(theCube,i));
cz := cz + st_z(pointn(theCube,i));
END LOOP;
/* Compute centroid of cube */
cx := cx / st_npoints(theCube);
cy := cy / st_npoints(theCube);
cz := cz / st_npoints(theCube);
/* WHAT WOULD THE APPROPRIATE STORAGE TYPE FOR THIS BE ??? */
retWKT := 'POLYGON( ';
for i in 1..st_npoints(theCube) loop
px := st_x(pointn(theCube,i));
py := st_y(pointn(theCube,i));
pz := st_z(pointn(theCube,i));
dx := st_x(pointn(theCube,i)) - cx;
dy := st_y(pointn(theCube,i)) - cy;
dz := st_z(pointn(theCube,i)) - cz;
/* Divide by distance from center point */
segLength := sqrt( (cx -px) ^ 2 + (cy - py) ^ 2 + (cz - pz) ^
2);
dx := dx / segLength;
dy := dy / segLength;
dz := dz /segLength;
/* Buffer the point */
px := px + dx;
py := py + dy;
pz := pz + dz;
retWKT := ' ( ' || px::text || ' ' || py::text || ' ' ||
pz::text || ' )';
end loop;
retWKT := ' )';
return setsrid(retWKT::geometry, st_srid(theCube));
END;
$BODY$
LANGUAGE 'plpgsql'
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
eehab hamzeh
Sent: Friday, August 15, 2008 1:51 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] 3d buffer
What i mean by 3d buffer are i have a room which is like a box
and i need to find all the areas that this room Box that will intersect
if the room are extended and get larger....
buffer FROM (SELECT gid,buffer(r.the_geom,10) as buffer FROM
room r WHERE r.roomname='guest room') AS foo USING UNIQUE gid USING
SRID=31467"
i need such query to take the 3d dimension in consideration and
make it not just only in 2d
Thanks
ihab
Get news, entertainment and everything you care about at
Live.com. Check it out! <http://www.live.com/getstarted.aspx>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080815/b3d47b2a/attachment.html>
