[postgis-users] 3d buffer
Sufficool, Stanley
ssufficool at rov.sbcounty.gov
Fri Aug 15 09:36:37 PDT 2008
Correction:
/* Buffer the point */
px := px + (dx * buffer);
py := py + (dy * buffer);
pz := pz + (dz * buffer);
retWKT := retWKT || ' ( ' || px::text || ' ' || py::text || ' '
|| pz::text || ' )';
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Sufficool, Stanley
Sent: Friday, August 15, 2008 8:34 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] 3d buffer
Step 1: Get center of cube by averaging all points (x,y,z) on
the cube
Step 2: Get the delta of each points (x,y,z) from the center
point and divide by distance from the center and then add/subtract that
delta from the points (x,y,z) multiplied by the buffer number
This would expand the CUBE from the center by the given amount.
Someone correct this if needed since I have absolutely no
practical application or data to drive this code.
VERY PSEUDO CODE (since there is no cube geometry type?):
CREATE FUNCTION st_buffercube(theCube geometry, buffer double
precision)
returns geometry AS $BODY$
declare i int;
/* Centroid of cube */
declare cx double precision;
declare cy double precision;
declare cz double precision;
/* Cube point */
declare px double precision;
declare py double precision;
declare pz double precision;
/* Cube point delta */
declare segLength double precision;
declare dx double precision;
declare dy double precision;
declare dz double precision;
/* Output ?CUBE? */
declare retWKT character varying(4096);
BEGIN
cx := 0;
cy := 0;
cz := 0;
for i IN 1..st_npoints(theCube) LOOP
cx := cx + st_x(pointn(theCube,i));
cy := cy + st_y(pointn(theCube,i));
cz := cz + st_z(pointn(theCube,i));
END LOOP;
/* Compute centroid of cube */
cx := cx / st_npoints(theCube);
cy := cy / st_npoints(theCube);
cz := cz / st_npoints(theCube);
/* WHAT WOULD THE APPROPRIATE STORAGE TYPE FOR THIS BE ???
retWKT := 'POLYGON( ';
for i in 1..st_npoints(theCube) loop
px := st_x(pointn(theCube,i));
py := st_y(pointn(theCube,i));
pz := st_z(pointn(theCube,i));
dx := st_x(pointn(theCube,i)) - cx;
dy := st_y(pointn(theCube,i)) - cy;
dz := st_z(pointn(theCube,i)) - cz;
/* Divide by distance from center point */
segLength := sqrt( (cx -px) ^ 2 + (cy - py) ^ 2 + (cz -
pz) ^ 2);
dx := dx / segLength;
dy := dy / segLength;
dz := dz /segLength;
px := px + dx;
py := py + dy;
pz := pz + dz;
retWKT := ' ( ' || px::text || ' ' || py::text || ' ' ||
pz::text || ' )';
end loop;
retWKT := ' )';
return setsrid(retWKT::geometry, st_srid(theCube));
END;
$BODY$
LANGUAGE 'plpgsql'
eehab hamzeh
Sent: Friday, August 15, 2008 1:51 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] 3d buffer
What i mean by 3d buffer are i have a room which is like
a box and i need to find all the areas that this room Box that will
intersect if the room are extended and get larger....
buffer FROM (SELECT gid,buffer(r.the_geom,10) as buffer
FROM room r WHERE r.roomname='guest room') AS foo USING UNIQUE gid USING
SRID=31467"
i need such query to take the 3d dimension in
consideration and make it not just only in 2d
Thanks
ihab
Get news, entertainment and everything you care about at
Live.com. Check it out! <http://www.live.com/getstarted.aspx>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080815/ce9b4845/attachment.html>
