[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Bresnahan, Mike Mike.Bresnahan at bestbuy.com
Mon Aug 18 07:12:22 PDT 2008
> How the hell do you get it to do a real union?
Heh. Intuitive ArcMap is not. It took me forever to figure it out as well. You can do a union a couple different ways. The way that seemed to work the best for this is to:
1) Run ArcMap
2) Add the shapefile to your map
3) Open the edit toolbar.
4) Click on Start Editing.
5) Select the entire dataset by left clicking and then dragging a rectangle around the geometry.
6) Select Union from the menu on the edit toolbar.
You should see the union happen right before your eyes.
I think I tried the Union Tool like you did and didn't get what I expected. I think it just did a union on each individual feature instead of doing an aggregate union.
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/2feca003/attachment.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/2feca003/attachment.pgp>
