[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Obe, Regina
robe.dnd at cityofboston.gov
Mon Aug 18 09:00:16 PDT 2008
Its supposed to merge and dissolve boundaries where as ST_Collect just
collects the geometries into one record.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of erik
Sent: Monday, August 18, 2008 10:48 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Isn't a Union supposed to merge all polygons in one? The only thing I
get to do this in ArcView is the "Merge" and that's also the
functionality I get from ST_Union.
Btw, for ST_Union'ing many complex polygons I'm using CascadedUnion as
written here:
http://postgis.refractions.net/pipermail/postgis-users/2007-December/017
995.html.
On Mon, Aug 18, 2008 at 4:12 PM, Bresnahan, Mike
<Mike.Bresnahan at bestbuy.com> wrote:
> How the hell do you get it to do a real union?
Heh. Intuitive ArcMap is not. It took me forever to figure it
out as well. You can do a union a couple different ways. The way that
seemed to work the best for this is to:
1) Run ArcMap
2) Add the shapefile to your map
3) Open the edit toolbar.
4) Click on Start Editing.
5) Select the entire dataset by left clicking and then dragging
a rectangle around the geometry.
6) Select Union from the menu on the edit toolbar.
You should see the union happen right before your eyes.
I think I tried the Union Tool like you did and didn't get what
I expected. I think it just did a union on each individual feature
instead of doing an aggregate union.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/1dc9cf98/attachment.html>
