[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Obe, Regina robe.dnd at cityofboston.gov
Mon Aug 18 09:02:20 PDT 2008
Thanks Mike,
  Yap that looks more like a union and was pretty fast, but then
couldn't figure out how to export it.
I right clicked on the layer - selected export data to shape.
Very strangely when I reopen the new shape file in ArcMap - it looks
unioned, but then when I open the same shape file in OpenJump - I can
still see the boundaries still and opening up the dbf there are clearly
274 records.  I even deleted the mxd, sbn, sbx files ArcMap created and
it still looked unioned when I reopened it in ArcMap and not unioned
when I look at it in open jump.
The union created in open jump is half the size of the ArcMap one too
and dbf is empty as I would expect since I didn't ask for any roll up of
attributes.
I'm very puzzled.  I have no idea why ArcMap shows this as unioned when
the size of the shape and the stats don't look that much different from
the original.  I'm sure I must be missing something here.
Stats looks like this is in open jump
Layer: OpenJumpUnion
Envelope: Env[-179.14734 : 179.77850341796875, 17.884813 :
71.35256064399981]
# Features: 1
  	Min 	Max 	Avg 	Total
Pts 	69795 	69795 	69795.0 	69795
Holes 	0 	0 	0.0 	0
Components 	219 	219 	219.0 	219
Area 	1104.3917345465716 	1104.3917345465716
Length 	733.4595414659133 	733.4595414659133
ArcMap Union
71.35256064399981]
# Features: 274
	Min 	Max 	Avg 	Total
Pts 	5 	45836 	688.0 	188644
Holes 	0 	0 	0.0 	0
Components 	1 	219 	1.0 	492
Area 	1.0783706500011592E-5 	1104.373302353546
8.061118897843844 	2208.7465780092134
Length 	0.013284095041776186 	733.3902842391406
8.213194606088345 	2250.4153220682065
Original
Layer: st99_d00
71.35256064399981]
# Features: 274
  	Min 	Max 	Avg 	Total
Holes 	0 	0 	0.0 	0
Signed,
Very confused Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Bresnahan, Mike
Sent: Monday, August 18, 2008 10:12 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] PostGIS 1.3.3 on Windows XP Unstable
> How the hell do you get it to do a real union?
Heh. Intuitive ArcMap is not. It took me forever to figure it out as
well. You can do a union a couple different ways. The way that seemed to
work the best for this is to:
1) Run ArcMap
2) Add the shapefile to your map
3) Open the edit toolbar.
4) Click on Start Editing.
5) Select the entire dataset by left clicking and then dragging a
rectangle around the geometry.
6) Select Union from the menu on the edit toolbar.
You should see the union happen right before your eyes.
I think I tried the Union Tool like you did and didn't get what I
expected. I think it just did a union on each individual feature instead
of doing an aggregate union.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/9ba28b23/attachment.html>
