[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Dane Springmeyer blake at hailmail.net
Mon Aug 18 13:21:40 PDT 2008
Regina,
To use the approach below you need to 'Stop Editing' so that the union
edits are written to the shapefile.
However, I think an easier approach is to not use the GUI Editing
interface and rather the 'Dissolve' tool in the (Geoprocessing tool
reference > Data Management toolbox > Generalization toolset > Tools),
which will take and input datasource and output a new one through the
'ArcToolbox' dialog.
Here is the direct link to the tool help (should help you find it in
the Toolbox view):
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Dissolve_(Data_Management)
A Happy-PosGIS-User-Once-A-Confused-Clicky-ArcGIS-User,
Dane
On Aug 18, 2008, at 9:02 AM, Obe, Regina wrote:
> Thanks Mike,
>   Yap that looks more like a union and was pretty fast, but then
> couldn't figure out how to export it.
> I right clicked on the layer - selected export data to shape.
> Very strangely when I reopen the new shape file in ArcMap - it looks
> unioned, but then when I open the same shape file in OpenJump - I
> can still see the boundaries still and opening up the dbf there are
> clearly 274 records.  I even deleted the mxd, sbn, sbx files ArcMap
> created and it still looked unioned when I reopened it in ArcMap and
> not unioned when I look at it in open jump.
> The union created in open jump is half the size of the ArcMap one
> too and dbf is empty as I would expect since I didn't ask for any
> roll up of attributes.
> I'm very puzzled.  I have no idea why ArcMap shows this as unioned
> when the size of the shape and the stats don't look that much
> different from the original.  I'm sure I must be missing something
> here.
> Stats looks like this is in open jump
> Layer: OpenJumpUnion
> Envelope: Env[-179.14734 : 179.77850341796875, 17.884813 :
> 71.35256064399981]
> # Features: 1
>  	Min	Max	Avg	Total
> Pts	69795	69795	69795.0	69795
> Holes	0	0	0.0	0
> Components	219	219	219.0	219
> Area	1104.3917345465716	1104.3917345465716	1104.3917345465716
> 1104.3917345465716
> Length	733.4595414659133	733.4595414659133	733.4595414659133
> 733.4595414659133
> ArcMap Union
> 71.35256064399981]
> # Features: 274
> Min	Max	Avg	Total
> Pts	5	45836	688.0	188644
> Holes	0	0	0.0	0
> Components	1	219	1.0	492
> Area	1.0783706500011592E-5 	1104.373302353546	8.061118897843844
> 2208.7465780092134
> Length	0.013284095041776186	733.3902842391406	8.213194606088345
> 2250.4153220682065
> Original
> Layer: st99_d00
> 71.35256064399981]
> # Features: 274
>  	Min	Max	Avg	Total
> Holes	0	0	0.0	0
> 2208.7465780092134
> 2250.4153220682065
> Signed,
> Very confused Regina
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net
> ] On Behalf Of Bresnahan, Mike
> Sent: Monday, August 18, 2008 10:12 AM
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] PostGIS 1.3.3 on Windows XP Unstable
> > How the hell do you get it to do a real union?
> Heh. Intuitive ArcMap is not. It took me forever to figure it out as
> well. You can do a union a couple different ways. The way that
> seemed to work the best for this is to:
> 1) Run ArcMap
> 2) Add the shapefile to your map
> 3) Open the edit toolbar.
> 4) Click on Start Editing.
> 5) Select the entire dataset by left clicking and then dragging a
> rectangle around the geometry.
> 6) Select Union from the menu on the edit toolbar.
> You should see the union happen right before your eyes.
> I think I tried the Union Tool like you did and didn't get what I
> expected. I think it just did a union on each individual feature
> instead of doing an aggregate union.
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/b6091bec/attachment.html>
