[postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Bresnahan, Mike
Mike.Bresnahan at bestbuy.com
Mon Aug 18 13:37:27 PDT 2008
Yes, and AFAIK, you need to create an empty shapefile ahead of time to
output the result to, otherwise ArcMap will add a new row/feature to the
existing layer, which most likely is not what anyone would want. Note
the layer st99_d00_union in my screenshots. It is not intuitive at all,
I know. I would simply use one of the stand-alone tools if I knew of one
that performs the operation I want. I tried the Dissolve tool, like you
suggested, (specifying no attributes) and it appeared to perform an
aggregate union in 3.0 seconds. ArcMap might be faster because it does
everything in-memory (i.e. it does no file I/O).
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dane
Springmeyer
Sent: Monday, August 18, 2008 3:22 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS 1.3.3 on Windows XP Unstable
Regina,
To use the approach below you need to 'Stop Editing' so that the union
edits are written to the shapefile.
However, I think an easier approach is to not use the GUI Editing
interface and rather the 'Dissolve' tool in the (Geoprocessing tool
reference > Data Management toolbox > Generalization toolset > Tools),
which will take and input datasource and output a new one through the
'ArcToolbox' dialog.
Here is the direct link to the tool help (should help you find it in the
Toolbox view):
http://webhelp.esri.com/arcgisdesktop/9.2/index.cfm?TopicName=Dissolve_(
Data_Management)
A Happy-PosGIS-User-Once-A-Confused-Clicky-ArcGIS-User,
Dane
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/c0c16d30/attachment.html>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080818/c0c16d30/attachment.pgp>
