[postgis-users] Flow Diagram Graphics
Clay, Bruce
bclay at ball.com
Thu Aug 21 11:09:28 PDT 2008
Bob:
Have you looked at OpenSceneGraph? There are examples / tools that mix GDAL with the abilities of 3D scene graphs. GDAL can interface to Postgres/PostGis.
Bruce
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob Pawley
Sent: Thursday, August 21, 2008 2:03 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Flow Diagram Graphics
Actually it's an engineering drawing that is known as a Process and
Instrument Diagram - a little more complex than a normal flow diagram, it
shows processes, piping to and from the processes and the devices that are
required to control the process.
I have it to the point of being able to add up to four process graphics and
identify the input and outputs that are needed. I'm using standard Postgis
functions to move and position each graphic. The graphics are driven by a
PostgreSQL database.
It seems to be quite doable using Postgis functions, however the graphic
display is the problem at the moment.
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, August 21, 2008 10:03 AM
> Hi Bob,
> Do you mean flowcharts in the sense of an org-chart? Rectangles or other
> shapes connected with arrows?
> I am not so sure if this is the strength of GIS software. There are tons
> of commercial and OS Software packages out there for flowcharts, starting
> with Visio and Inspiration on the commercial side, and continueing with
> dia, graphviz, kivio and others on the OS side. Most of these packages
> support SVG export - some of them are also scriptable - means usable on a
> webserver.
> I agree that SVG makes a lot of sense for presenting flow-charts.
> Do you need to generate those flowcharts automatically - db-driven?
> What specific GIS feature are you intending to use for the flowchart
> generation?
> Andreas
> Bob Pawley wrote:
>> As some of you may know, I am working with Postgis to create a flow
>> diagram. So far, considering the challenges and my learning ability, I
>> have been making good progress.
>> I have been using QuantumGIS as a graphical tool. However I now think it
>> is time to seek a graphic display that is more suitable for my purpose.
>> Ideally, I would want the display area to be full screen, limited pan and
>> zoom and be able to lock the needed Postgis table(s) to the display.
>> I have looked at developing SVG for this purpose, but it looks rather
>> intimidating for my level of competance.
>> Would anyone have an idea for a solution that they may wish to share??
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Andreas Neumann
> Böschacherstrasse 6
> CH-8624 Grüt (Gossau ZH)
> Switzerland
> Phone: ++41-44-2736668
> Email: a.neumann at carto.net
> Web: http://www.carto.net/neumann/
> SVG Examples: http://www.carto.net/papers/svg/samples/
> SVG.Open: http://www.svgopen.org/
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
