[postgis-users] postgis install error in windows
Gustavo Ces
g.ces at pettra.es
Fri Aug 22 03:44:21 PDT 2008
Hi Mark,
yes, it´s a windows file permissions problem. But i´m the administrator
so i don´t know... Googling i've found there´re problems with read only
attribute in windows xp ( but it nevers was a problem until now). You can´t
change read-only attribute with some folders ... But it´s not a problem for
windows to delete that read-only folders ( well, sometimes yes). I can
delete postgresql installation folder but can´t write files into the same
folder...
But what i can´t understand is what is different now : i have installed
previous version of both postgresql and postgis and never had this issue.
Maybe something have changed in postgresql install method? I´ll search in
postgresql forum...
And other problem is, why can´t i find any other info about this topic in
Inet? It seems a problem in my computer... Any examples of successfull
installation of postgresql 8.3.3.1 with postgis 1.3.3 or 1.3.2 will be
welcomed! :)
I´ll try to install postigs in other computer this afternoon...
Gus
----- Original Message -----
From: "Mark Cave-Ayland" <mark.cave-ayland at siriusit.co.uk>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, August 22, 2008 11:14 AM
Subject: Re: [postgis-users] postgis install error in windows
> Gustavo Ces wrote:
>> Hi all,
>> i´m trying to upgrade my postgresql version ( it was 8.2) in windows ,
>> so i' ve downloaded and installed postgresql 8.3. When i try to install
>> postgis 1.3.3 with the Application Stack Builder and after downloading
>> the postgis installer, appears an error
>> "Error opening file for writing" ( see jpg)
>> everytime it wants to copy a file to the install_folder.
>> I was changed the directory name, i have downloaded postgis installation
>> files from pgFoundry, i have changed to postgis 1.3.2 but nothing works.
>> Any help?
>> Thanks in advance,
>> Gus
> Hi Gus,
> It almost looks like it's just a simple file permissions problem. Are you
> running the installer as an administrator, and does the administrator user
> have the correct file permissions on the relevant directories?
> HTH,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
