[postgis-users] postgis install error in windows
Gustavo Ces
g.ces at pettra.es
Fri Aug 22 04:45:51 PDT 2008
Hi all,
sorry for this off-topic! In the end was a windows permissions problem,
not an installer one.
Now it´s solved. You only have to grant permissions in windows manually.
Gus
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Friday, August 22, 2008 12:44 PM
Subject: Re: [postgis-users] postgis install error in windows
> Hi Mark,
> yes, it´s a windows file permissions problem. But i´m the administrator
> so i don´t know... Googling i've found there´re problems with read only
> attribute in windows xp ( but it nevers was a problem until now). You
> can´t change read-only attribute with some folders ... But it´s not a
> problem for windows to delete that read-only folders ( well, sometimes
> yes). I can delete postgresql installation folder but can´t write files
> into the same folder...
> But what i can´t understand is what is different now : i have installed
> previous version of both postgresql and postgis and never had this issue.
> Maybe something have changed in postgresql install method? I´ll search in
> postgresql forum...
> And other problem is, why can´t i find any other info about this topic in
> Inet? It seems a problem in my computer... Any examples of successfull
> installation of postgresql 8.3.3.1 with postgis 1.3.3 or 1.3.2 will be
> welcomed! :)
> I´ll try to install postigs in other computer this afternoon...
> Gus
> From: "Mark Cave-Ayland" <mark.cave-ayland at siriusit.co.uk>
> Sent: Friday, August 22, 2008 11:14 AM
>> Gustavo Ces wrote:
>>> Hi all,
>>> i´m trying to upgrade my postgresql version ( it was 8.2) in windows ,
>>> so i' ve downloaded and installed postgresql 8.3. When i try to install
>>> postgis 1.3.3 with the Application Stack Builder and after downloading
>>> the postgis installer, appears an error
>>> "Error opening file for writing" ( see jpg)
>>> everytime it wants to copy a file to the install_folder.
>>> I was changed the directory name, i have downloaded postgis installation
>>> files from pgFoundry, i have changed to postgis 1.3.2 but nothing works.
>>> Any help?
>>> Thanks in advance,
>>> Gus
>> Hi Gus,
>> It almost looks like it's just a simple file permissions problem. Are you
>> running the installer as an administrator, and does the administrator
>> user have the correct file permissions on the relevant directories?
>> HTH,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
