[postgis-users] Memory problem with ST_Within
Birgit Laggner birgit.laggner at vti.bund.de
Mon Aug 25 03:33:49 PDT 2008
Frank Koormann schrieb:
> * Birgit Laggner <birgit.laggner at vti.bund.de> [080821 09:59]:
>> Hallo Regina, hallo Frank,
>> thanks for your suggestions!
>> Leaving out the_geom didn't solve the problem - I still ran out of memory.
>> I attached my postgresql.conf settings and the result of the EXPLAIN
>> ANALYSE SELECT to this e-mail.
> Hm, the explain analyse finishes successfully. Explain analyse actually
> execute the query (in your case in 675 milliseconds), so the problem seems
> to be returning the results to pgAdmin, assuming that the queries run on
> the same data set.
> Your memory related settings are already significantly increased.
> Without knowledge about your system if too high.
> Other points:
> - What is the full error message?
> - Do you have more success when using psql instead of pgAdmin?
> Regards,
>         Frank
Hallo Frank,
this is actually a misunderstanding: of course, the Explain analyse did
not run on the full dataset either, therefore I started the Explain
analyse for my test dataset, which I used to test if my query is working
at all.
The full error message is:
ERROR: Memory exhausted
SQL Status:53200
Detail: Failed on request of size 32.
I'm still testing if psql is more successful then pgAdmin. Results
tomorrow...
Thank you!
Regards,
Birgit.
Mark Cave-Ayland schrieb:
> Hi Birgit,
> If PostgreSQL stops due to lack of memory, it generally dumps
> information about memory usage into the server log file before it
> terminates. Can you see any such information in your PostgreSQL log
> file? If so, posting it here would help greatly, along with the output
> of "SELECT postgis_full_version()".
> ATB,
> Mark.
Hallo Mark,
this is my postgis version:
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS"
The memory usage information of the PostgreSQL log file, I attached to
the e-mail (pg.log).
Thank you!
Regards,
Birgit.
Type: application/x-sas-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080825/cb0b83c0/attachment.bin>
