[postgis-users] schema name for a temp table?
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Tue Aug 26 10:25:08 PDT 2008
OK,
So, what advantage is conferred by the use of the geometry_columns
table?
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
David William Bitner
Sent: Tuesday, August 26, 2008 9:55 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] schema name for a temp table?
Nope, you don't have to use addgeometrycolumn at all.  You just need to
create a table with a column declared as geometry.
Create table foo (my_geom_column geometry, my_id serial, my_attribute
varchar);
On Tue, Aug 26, 2008 at 8:20 AM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
Kevin,
Thanks for the response.  By spatially enabled, I mean, has a geometry
column, and I wish to use that column for comparison operators, such as
st_within().  Furthermore, since I am adding the column to a table of
data, then setting the geom column to table lat/lon values, I needed to
use addgeometrycolumn (at least I think that I need to do that).
Anyhow, your query gives me just the information that I need.  Thanks!
r.b.
804-698-4405
Kevin Neufeld
Sent: Monday, August 25, 2008 5:51 PM
SELECT nspname FROM pg_namespace WHERE oid = pg_my_temp_schema();
But what exactly do you mean by "spatially enabled"?  Any table with a
geometry column is "spatially enabled".  It may not be registered with
the geometry_columns metadata table or have spatial constraints on it,
but it is capable of holding spatial data.
ie.
CREATE TEMP TABLE test (id integer, the_geom geometry);
\d
     Table "pg_temp_11.test"
  Column  |   Type   | Modifiers
 id       | integer  |
 the_geom | geometry |
Cheers,
Kevin
Burgholzer,Robert wrote:
> I have a temporary table that I would like to spatially enable.  Thus,
I
> need to know the proper schema name, assuming that the schema name
would
> change if there were multiple temp tables with the same name (a
> possibility if several users are hitting the app simultaneously).
> Has anyone had any experience with this?
> Thanks!
> r/b/
> 804-698-4405
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080826/92a78ac1/attachment.html>
