[postgis-users] AddGeometryColumn error
Nicolas Ribot nicky666 at gmail.com
Wed Aug 27 04:30:09 PDT 2008
> Yes, the tabla estac_aemet exists. The schema is public
Did you create the table using double quotes to name it ? "ESTAC_AEMET" maybe ?
If so, then you have to respect the case in the table name when naming it:
SELECT addgeometrycolumn('public','ESTAC_AEMET', 'the_geom', 23030,'POINT',2)
You can check the table name by launching psql and typing \d to list all tables.
Nicolas
