[postgis-users] AddGeometryColumn error
javier.estevez.ext at juntadeandalucia.es
Wed Aug 27 04:50:40 PDT 2008
No, is correct like 'estac_aemet'
How do I know if my POSTGIS functions are installed ok?
In my DB called 'postgres' I have no Functions.
>> Yes, the tabla estac_aemet exists. The schema is public
> Did you create the table using double quotes to name it ? "ESTAC_AEMET" maybe
> If so, then you have to respect the case in the table name when naming it:
> SELECT addgeometrycolumn('public','ESTAC_AEMET', 'the_geom', 23030,'POINT',2)
> You can check the table name by launching psql and typing \d to list all
> tables.
> Nicolas
> postgis-users mailing list
