[postgis-users] Union, Collects ?? - Need Help
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Wed Aug 27 05:16:33 PDT 2008
Carmen,
The trouble here is not with PostGIS per se, but with the SQL statement
and what Qgis expects. When Qgis loads a table from postgres, it wants
there to be a column named OID.
You can do this by creating a view that includes an OID column -
although this is most easily done if your table already has an OID
column -- can you view your table of states in Qgis??. If your table
has an OID column and you can view it in Qgis, you could do this:
SELECT Min(OID) as OID, ST_Union(s.the_geom) AS reggeo, reg
FROM usa.us_states As s,
GROUP BY reg
The other option is to create a new table of regions, given the fact
that the EPA regions (I assume this is what you are getting at) are
static, this is a decent option as well. You could do this by:
CREATE TABLE epa_regions (
OID SERIAL,
reg varchar(64)
select addGeometryColumn('public', 'epa_regions', 'MULTIPOLYGON', 2);
INSERT INTO epa_regions (reg, the_geom)
SELECT reg, ST_Union(s.the_geom) AS reggeo
GROUP BY reg;
This should work for you. Good luck!!
r.b.
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Constantine.Carmen at epamail.epa.gov
Sent: Tuesday, August 26, 2008 1:56 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Union, Collects ?? - Need Help
I am very new to PostGIS (about 1 month of trial and error). I think
that I am close to solving this issue, but I just can't get it.
Here is
my issue:
I have a table of us_states, 50 records, one per state. So even
states
with multiple island polys are represented as on record. Each state
has
a Region code. So, and example, Region 2 is NY and NJ; Region 1 is
ME,
NH, VT, RI, CT, and MA; etc. I want to select-out each region as a
View.
I want that View to have one geometry. If the borders between states
are
"dissolved", that's fine too, but not necessary. So in my View for
Region 2, even though it will contain two states (NY, NJ), I would
like
those two entities to behave as one geometry. Did I say that right?
I
have Tried:
ST_Union, ST_Collects, Geom_Union. In most cases a 'View' is
created,
but it will not display in QGIS. An error displays that indicates
that
OID, or Keyfield does not exist. I have even tried a piece of code:
GROUP BY. I am very familiar with ESRI, I am thinking that you need
to
do a select by Region. This shouldn't be that difficult. Can someone
please help me??
Here are some examples:
GROUP BY reg
OR
SELECT ST_Collect(the_geom)AS reg_geom
id, reg
FROM usa.us_states
WHERE reg = '03';
Carmen Constantine
US EPA Region 3 GIS Team
Vistronix, Inc
On-Site Contractor
215-814-5418
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
