[postgis-users] AddGeometryColumn error
javier.estevez.ext at juntadeandalucia.es
Thu Aug 28 03:12:10 PDT 2008
Thank you very much for all. Now everything is OK.
I load PostGIS functions with 'lwpostgis.sql' into my DB, and all it's OK.
Now, I have created a geometric column and using geometryfromtext I have
introduced all the POINTS.
Thanks again...
Javier Estévez
> ¡Hola Javier!
> Maybe you did not create your database properly...
> from http://www.postgis.org/documentation/
> createlang plpgsql postgres
> psql -d postgres -f lwpostgis.sql
> psql -d postgres -f spatial_ref_sys.sql
> the two scripts could be in a number of places on your system: if you
> built postgis from source, in your build directory, or maybe in
> /usr/share/postgresql/8.3/contrib, or... you might have to look around a
> bit :-)
> javier.estevez.ext at juntadeandalucia.es wrote:
>> I tried one thing:
>> I create a new table in the database including PostGIS functions. This query
>> is CORRECT now:
>> SELECT addgeometrycolumn('public','tablenew','the_geom',23030,'POINT',2)
>> The problem right now is... How can I import the PostGIS functions into my
>> DATABASE??????
>>> The function is there and executing, however it is complaining that it
>>> cannot find the table name in the public schema.
>>> What was your original table create statement for the "estac_aemet"
>>> table? "CREATE TABLE public.estac_aemet (field type, etc... "
>>> Did you use special accent characters in its creation?
>>>> -----Original Message-----
>>>> From: postgis-users-bounces at postgis.refractions.net
>>>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>>>> Behalf Of javier.estevez.ext at juntadeandalucia.es
>>>> Sent: Wednesday, August 27, 2008 8:13 AM
>>>> To: PostGIS Users Discussion
>>>> Cc: PostGIS Users Discussion
>>>> Subject: Re: [postgis-users] AddGeometryColumn error
>>>> Correctly, I have 3 databases: postgres (This my DB),
>>>> demo_postgis and template_postgis
>>>> In my DB there is no FUNCTIONS
>>>> In template_postgis there are all the POSTGIS functions.
>>>> Can I import from 'my DB' all PostGIS functions that are in other DB
>>>> (template_postgis)
>>>> Thanks.
>>>>> Hi,
>>>>> maybe your instalation of postgis functions and etc are not in
>>>>> postgres db. If you are using windwos search for others databases,
>>>>> maybe a postgis or postgis_template. At that databases you
>>>> will find
>>>>> the the functions.
>>>>> If you are using linux then you will have to add that functions to
>>>>> some database, see the docs for a how-to.
>>>>> A good policy is to create a new database using a template with the
>>>>> postgis stuff. Leave the postgres db for maintenance.
>>>>> Best regards,
>>>>> 2008/8/27 <javier.estevez.ext at juntadeandalucia.es>
>>>>>> No, is correct like 'estac_aemet'
>>>>>> How do I know if my POSTGIS functions are installed ok?
>>>>>> In my DB called 'postgres' I have no Functions.
>>>>>>>> Yes, the tabla estac_aemet exists. The schema is public
>>>>>>> Did you create the table using double quotes to name it ?
>>>>>>> "ESTAC_AEMET"
>>>>>> maybe
>>>>>>> If so, then you have to respect the case in the table name when
>>>>>>> naming
>>>>>> it:
>>>>>>> SELECT addgeometrycolumn('public','ESTAC_AEMET', 'the_geom',
>>>>>> 23030,'POINT',2)
>>>>>>> You can check the table name by launching psql and typing \d to
>>>>>>> list all tables.
>>>>>>> Nicolas
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list postgis-users at postgis.refractions.net
>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>> Luigi Castro Cardeles
> Regards,
> Chris Hermansen mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
