[postgis-users] AddGeometryColumn error
javier.estevez.ext at juntadeandalucia.es
Wed Aug 27 08:12:57 PDT 2008
Correctly, I have 3 databases: postgres (This my DB), demo_postgis and
template_postgis
In my DB there is no FUNCTIONS
In template_postgis there are all the POSTGIS functions.
Can I import from 'my DB' all PostGIS functions that are in other DB
(template_postgis)
Thanks.
> Hi,
> maybe your instalation of postgis functions and etc are not in postgres db.
> If you are using windwos search for others databases, maybe a postgis or
> postgis_template. At that databases you will find the the functions.
> If you are using linux then you will have to add that functions to some
> database, see the docs for a how-to.
> A good policy is to create a new database using a template with the postgis
> stuff. Leave the postgres db for maintenance.
> Best regards,
> 2008/8/27 <javier.estevez.ext at juntadeandalucia.es>
>> No, is correct like 'estac_aemet'
>> How do I know if my POSTGIS functions are installed ok?
>> In my DB called 'postgres' I have no Functions.
>> >> Yes, the tabla estac_aemet exists. The schema is public
>> > Did you create the table using double quotes to name it ? "ESTAC_AEMET"
>> maybe
>> > If so, then you have to respect the case in the table name when naming
>> it:
>> > SELECT addgeometrycolumn('public','ESTAC_AEMET', 'the_geom',
>> 23030,'POINT',2)
>> > You can check the table name by launching psql and typing \d to list all
>> > tables.
>> > Nicolas
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Luigi Castro Cardeles
