[postgis-users] Compare data in one table
Broun Uganda
tekuganda at hotmail.com
Fri Aug 29 14:23:33 PDT 2008
I am trying to develop a trigger function that searches for lines with particular properties. I have two or more lines joining at a point but only one line exiting from that point. I want to check that the size of the outgoing (exiting) line is always not smaller than incoming lines.
Take such data as example:
line_name from_point to_point size
line1 p1 p2 2
line2 p10 p2 3
line3 p2 p7 1
line4 p7 p8 3
Lines Line1 and Line2 join at point p2 (to_point), therefore line3 should have size at least equal to 3.
Tried to use this select statement but doesnt work, could anyone give me an idea
Select link_name, diameter, from_node, to_node from links as ends where ends.diameter< links.diameter;
or even
SELECT from_node from links as dstream intersect SELECT to_node from links as previo ;
Thank you
Broun Uganda
_________________________________________________________________
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080830/12a4530c/attachment.html>
