[postgis-users] Compare data in one table
Kevin Neufeld
kneufeld at refractions.net
Fri Aug 29 18:49:39 PDT 2008
What about something like this.
SELECT a.to_point, a.in_size, b.out_size
FROM
(SELECT to_point, max(size) AS in_size FROM links GROUP BY to_point) AS a,
(SELECT from_point, size AS out_size FROM links) AS b
WHERE a.to_point = b.from_point
AND b.out_size < a.in_size;
-- Kevin
Broun Uganda wrote:
> I am trying to develop a trigger function that searches for lines with
> particular properties. I have two or more lines joining at a point but
> only one line exiting from that point. I want to check that the size
> of the outgoing (exiting) line is always not smaller than incoming lines.
> Take such data as example:
> line_name from_point to_point size
> line1 p1 p2 2
> line2 p10 p2 3
> line3 p2 p7 1
> line4 p7 p8 3
> Lines Line1 and Line2 join at point p2 (to_point), therefore line3
> should have size at least equal to 3.
> Tried to use this select statement but doesnt work, could anyone give
> me an idea
> Select link_name, diameter, from_node, to_node from links as ends
> where ends.diameter< links.diameter;
> or even
> SELECT from_node from links as dstream intersect SELECT to_node
> from links as previo ;
> Thank you
> Broun Uganda
> Discover the new Windows Vista Learn more!
> <http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE>
> postgis-users mailing list
