[postgis-users] Postgres/PostGIS and date field
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Dec 2 03:16:34 PST 2008
Vincenzo Patruno wrote:
> Hi list!
> In my file .map I wrote something like
> select the_geom .......... (end_date - now() >= 10) as green and (end_date - now() < 0) as red .... from ....
> The idea is using different coloured markers for expired points or valid points
> After upgrading Postgres/Gis with last available versions, the query above doesn't work anymore because I cannot compare date types with integers .......
> Any idea?
> Thanks in advance
> Vinc
Hi Vinc,
This sounds like the casting changes in 8.3 are hitting you here. Have
you tried something like this:
select the_geom .......... (end_date - now() >= '10 days'::interval) as
green and (end_date - now() < '0'::interval) as red .... from ....
I'm not sure exactly what units you were using, but you should be able
to work with the example above to get what you want.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
