[postgis-users] Re: Problem with MultiLineString
Ken Southerland
southerland at samsix.com
Wed Dec 3 12:39:53 PST 2008
Sorry, I copied the wrong error message after the query, that was from a
multipolygon issue that I was simultaneously investigating. The real
message for this is ...
NOTICE: Too few points in geometry component at or near point 491216 532661
Sorry for the misinformation. Still in need of help! :)
Ken
Ken Southerland wrote:
> This problem occurs on versions...
> POSTGIS="1.3.1" GEOS="3.0.0rc4-CAPI-1.3.3" PROJ="Rel. 4.5.0, 22 Oct 2006"
> POSTGIS="1.3.2" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
> The first query gives...
> select st_isvalid( st_GeomFromText('MULTILINESTRING((491181.9816
> 532686.6037,491209.6059 532664.6521),(491215.9577
> 532660.8051,491215.9577 532660.8051))'));
> NOTICE: IllegalArgumentException: Number of points must be 0 or >3
> st_isvalid
> f
> ... while the second gives...
> 532686.6037,491209.6059 532664.6521),(491215.957 532660.8051,491215.9577
> 532660.8051))'));
> st_isvalid
> t
> ...and the only difference between the two is that the first point of
> the second line has an x value of 491215.9577 in the first query and
> 491215.957 in the second. In other words, the last seven is just
> stripped and it works.
> What gives here?! Any ideas?
> Ken Southerland
