[postgis-users] relationship functions not working well
Martin Davis
mbdavis at refractions.net
Fri Dec 5 10:44:54 PST 2008
Yep, relate doesn't automatically use the spatial index. You could also
use the && operator as a filter condition - that will avoid running
intersects unecessarily.
William Kyngesburye wrote:
> On Dec 5, 2008, at 11:22 AM, Martin Davis wrote:
>> Good news! I thought about this some more overnight, and I realized
>> that the relation "interior-intersects" should produce the result
>> you're looking for. This still doesn't have a named predicate, but
>> the really good news is that the IM pattern for this is trivial:
>> [T********] .
>> (Exercise left for the student: Prove that the pattern expression for
>> "intersects-and-not-touches" is equivalent to [T********]. Or not -
>> the proof in either situation would be interesting)
> Well, that works:
> ST_relate(wkb_geometry, SetSRID('BOX3D(-162 55,-161 56)'::box3d,4326),
> 'T********')
> But it's painfully slow - looks like relate doesn't do an index
> bounding box test.
> ... added a normal intersect (it's a superset of what I want) and let
> short-circuit logic take care of the initial selection:
> ST_Intersects(wkb_geometry, SetSRID('BOX3D(-162 55,-161
> 56)'::box3d,4326)) AND ST_relate(wkb_geometry, SetSRID('BOX3D(-162
> 55,-161 56)'::box3d,4326), 'T********')
> That's reasonably fast, for a small box at least. It will likely slow
> down on a larger box.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
