[postgis-users] relationship functions not working well
    William Kyngesburye
    woklist at kyngchaos.com
    Fri Dec  5 11:30:59 PST 2008
On Dec 5, 2008, at 1:02 PM, Paul Ramsey wrote:
> add
> wkb_geometry && SetSRID('BOX3D(-162 55,-161 56)'::box3d,4326)
> to your where clause to engage the index.
> P
Do you mean just that, without the st_relate?  That gives exactly the
same results as st_intersects, though may be a little faster since it
skips the full intersection test.
Or replace the st_intersects half?  Again, probably slightly faster.
Doesn't help the st_relate half in a large box selection.
>> Well, that works:
>> ST_relate(wkb_geometry, SetSRID('BOX3D(-162 55,-161 56)'::box3d,
>> 4326),
>> 'T********')
>> But it's painfully slow - looks like relate doesn't do an index
>> bounding box
>> test.
>> ... added a normal intersect (it's a superset of what I want) and let
>> short-circuit logic take care of the initial selection:
>> ST_Intersects(wkb_geometry, SetSRID('BOX3D(-162 55,-161 56)'::box3d,
>> 4326))
>> AND ST_relate(wkb_geometry, SetSRID('BOX3D(-162 55,-161 56)'::box3d,
>> 4326),
>> 'T********')
>> That's reasonably fast, for a small box at least.  It will likely
>> slow down
>> on a larger box.
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Those people who most want to rule people are, ipso-facto, those
>> least
>> suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
least suited to do it."
