[postgis-users] how to identify the_geom that cause:RelateOperation called withLWGEOMCOLLECTION type
Martin Davis mbdavis at refractions.net
Wed Dec 10 09:35:33 PST 2008
Congratulations, you've uncovered a long-standing bug in JTS.  Taking
the centroid of a polygon with zero area (or very close to it) results
in an invalid point value for the centroid.
This doesn't apply to linear features, so one workaround is to take the
centroid of the *boundary* of the polygon if it has zero area (or very
close to it).
I'm working on a fix for JTS right now - it should be fairly simple to
port to GEOS.
Ghislain Geniaux wrote:
> Exact,
>  that's the problem :
> scot3=# SELECT gid, the_geom
> scot3-# FROM bd_dispo_final
> scot3-# WHERE isempty(centroid(the_geom));
>   gid
>        the_geom
>  16435 |
> 0103000020BE6B0000010000000400000081F178483F4F2841D730212506D33C418045F71F474F2841D706623902D33C417E45F71F474F2841D806623902D33C4181F178483F4F2841D730212506D33C41
> (1 row)
> Here, you will find  the ouput of  pg_dump to study this geometrry.
> Thanks again.
> -- PostgreSQL database dump
> SET client_encoding = 'SQL_ASCII';
> SET standard_conforming_strings = off;
> SET check_function_bodies = false;
> SET client_min_messages = warning;
> SET escape_string_warning = off;
> SET search_path = public, pg_catalog;
> SET default_tablespace = '';
> SET default_with_oids = false;
> -- Name: bug; Type: TABLE; Schema: public; Owner: postgres; Tablespace:--
> CREATE TABLE bug (
>     gid integer,
>     the_geom geometry
> ALTER TABLE public.bug OWNER TO postgres;
> -- Data for Name: bug; Type: TABLE DATA; Schema: public; Owner: postgres
> COPY bug (gid, the_geom) FROM stdin;
> 16435
> -- PostgreSQL database dump complete
> Le 9 déc. 08 à 13:04, Obe, Regina a écrit :
>> Ghislain,
>> The only time I have seen this kind of behavior is when centroid
>> returns an empty geometry collection.  In those cases its because the
>> geometry is invalid.
>> Although none of your geometries are invalid, it could be a bug in
>> either the centroid code or isvalid check that may or may not be
>> fixed in 3.0.3+ of GEOS.
>> Can you do the following
>> FROM ZS2C
>> and send us as an attatched file with one of those geometries.  We
>> can cross check with GEOS 3.0.3 or 3.1 to see if the issue still
>> remains.
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Ghislain Geniaux
>> Sent: Monday, December 08, 2008 1:29 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] how to identify the_geom that
>> On Linux  :
>> POSTGIS="1.3.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
>> 2007" USE_STATS
>> (1 row)
>> On Macos
>>   POSTGIS="1.2.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
>> 2007" USE_STATS
>> (1 row)
>> same result with the two platform and postgis version.
>> Thanks.
>> Le 8 déc. 08 à 17:53, Paragon Corporation a écrit :
>>> What does
>>> SELECT postgis_full_version();
>>> Return
>>> Thanks,
>>> Regina
>>> Ghislain
>>> Geniaux
>>> Sent: Monday, December 08, 2008 11:03 AM
>>> Subject: Re: [postgis-users] how to identify the_geom that cause
>>> I've no collection. It's looks like a bug.
>>> Moreover my table is very large wiht more than 500 000 geometry and i
>>> found no solution to identy the wrong geom.
>>> Here you can see the query, with the same result on different
>>> plateform (LINUX DEBIAN, MACOS, with GEOS 3)
>>> otm=# select distinct geometrytype(the_geom) from ZS2c;
>>>   geometrytype
>>>   MULTIPOLYGON
>>> (1 row)
>>> otm=# select distinct geometrytype(the_geom) from bd_dispo_finalc ;
>>>   geometrytype
>>>   MULTIPOLYGON
>>>   POLYGON
>>> (2 rows)
>>> otm=# create table info_nonvoue1 as
>>> otm-# select b.id_parc, z.niv from bd_dispo_finalc as b, ZS2c as z
>>> otm-# where z.niv=1 and intersects(centroid(b.the_geom),z.the_geom)
>>> and b.the_geom && z.the_geom and isvalid(b.the_geom) and isvalid
>>> (z.the_geom);
>>> ERROR:  Relate Operation called with a LWGEOMCOLLECTION type.  This
>>> is unsupported
>>> otm=#
>>> Le 8 déc. 08 à 13:32, Obe, Regina a écrit :
>>>> Many of the GEOS relation functions do not work with collections.
>>>> You must have a geometry collection in there somewhere or its a bug.
>>>> Also which relation function were you trying?
>>>> To figure out the type of your geometries, run
>>>> SELECT *
>>>> FROM sometable
>>>> WHERE GeometryType(the_geom) = 'GEOMETRYCOLLECTION'
>>>> Nicolas Ribot
>>>> Sent: Monday, December 08, 2008 6:22 AM
>>>> Subject: Re: [postgis-users] how to identify the_geom that cause :
>>>>> I have an error with some geometry that cause : "ERROR Relate
>>>> Operation
>>>>> called withLWGEOMCOLLECTION type".
>>>>> All the geometries seem clean (valid, non empty, closed, only
>>>>> POLYGON,
>>>>> My question : how to get information of which geometry cause the
>>>> problem ?
>>>>> Is there a way  to have information about the geometry during
>>>>> postgis
>>>> is
>>>>> working on a  SQL query ?
>>>>> Thanks.
>>>> Hi Ghislain,
>>>> What the query that failed looks like ?
>>>> The message is telling that one geometry has an invalid type.
>>>> In your query, you could try to ask for ST_GeometryType(geometry) and
>>>> a geometry identifier to see which geometry has the wrong type.
>>>> If you perform a spatial operation, it is possible that
>>>> geometryCollection is produced.
>>>> You could maybe split your query into smaller block to see where such
>>>> collections are generated.
>>>> Nicolas
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
>>> Geniaux Ghislain
>>> INRA SAD Ecodéveloppement
>>> Site Agroparc
>>> Domaine St Paul
>>> 84914 Avignon Cedex 9
>>> Tél : 04 32 72 25 64
>>> Fax : 04 32 72 25 62
>> Geniaux Ghislain
>> Site Agroparc
>> Domaine St Paul
> Geniaux Ghislain
> Site Agroparc
> Domaine St Paul
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
