[postgis-users] PgRouting schema qualified tables etc.
Daniel Kastl
orkney at gmx.de
Thu Dec 11 02:30:12 PST 2008
Hi Horst,
Thank you for this comment with code!
If you agree then I will move it to the pgRouting TRACK and create a ticket.
Or do you like to do this yourself?
Daniel
Düster Horst schrieb:
> Hi
> I played a little bit with pgrouting to build a routing plugin client for QGIS. In principle it works fine but I found out some annoyances:
> 1. The functions like shortest_path, dijkstra etc. don't respect schema qualified tables.
> 2. always it is supposed and hard coded that GID is the primary key column of the table.
> 3. always it is supposed and hard coded that the_geom is the column name of the geometry column.
> I have attached a modified version of the dijkstra_sp function to make this function more generic.
> Perhaps you can modify all other dependencies of the pgRouting functions in this way.
> Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> postgis-users mailing list
