[postgis-users] Changed bahaviour of PostGIS confuses MapServer
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Fri Dec 12 07:49:46 PST 2008
Mark Cave-Ayland wrote:
> Peter Hopfgartner wrote:
>> Dear MLs,
>> sorry for cross-posting to both, PostGIS and MS, but seems to rtouch
>> both.
>> I've tried to install PostGIS 1.3.4 on a CentOS 5 server with
>> MapServer 5.2.1 and PostgreSQL 8.2.11.
>> the command:
>> shp2img -l prova -e 1587541 5116731 1591730 5120008 -m prova.map >
>> ../../public/technet/test-<pgis-version>.png
>> (a simple line layer)
>> Upgrading to 1.3.4 the picture became as in test-postgis-1.3.4-1.png,
>> an empty picture.
>> The relevant mapfile fragment is Mapfile.frag.txt, the SQL table
>> definition is e405.sql, all objects are MULTILINESTRINGs [SELECT
>> DISTINCT geometrytype(the_geom) FROM public.e405 results in
>> MULTILINESTRING], the geometry column is registered as
>> MULTILINESTRING in geometry_columns.
>> Running the MapServer query:
>> SELECT
>> asbinary(force_collection(force_2d(the_geom)),'NDR'),common_uid::text
>> from public.e405 WHERE (tiplinapp is not null) and (the_geom &&
>> setSRID( 'BOX3D(1587541 5116702.44897959,1591730
>> 5120036.55102041)'::BOX3D,find_srid('','public.e405','the_geom') ))
>> changed for better result readability into:
>> SELECT AsEWKT(force_collection(force_2d(the_geom))),common_uid::text
>> by hand gives slightly different results, as shown in the attached
>> files.
>> To make a long story short, 1.3.4 seems to better preserve the
>> MULTILINESTRING, but this seems to confuse MapServer.
>> Regards,
>> Peter
> Hi Peter,
> This is likely the known issue with MULTILINESTRINGs in 1.3.4 causing
> segfaults :( The patch you need is very simple and can be found here:
> http://postgis.refractions.net/pipermail/postgis-commits/2008-December/000866.html
> if you can't wait for a 1.3.5 release. Please let us know whether this
> resolves the problem for you.
> HTH,
> Mark.
Good catch! Now everything is fine.
Thanks,
Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
