[postgis-users] Problem loading shape data
John Zhang
johnzhang06 at gmail.com
Fri Dec 12 15:17:53 PST 2008
Hi there,
I used shp2pgsql command to convert shape data to postgis. I met a problem
when I tried to run the generated sql data file.
The command is as follows:
shp2pgsql -s 3005 "..\AbaloneClosures.shp" hm_vect.AbaloneClosures >
D:\tmp\AbaloneClosures.sql | psql -h flash.HaidaMapping.local -d hm -U
postgres -f D:\tmp\AbaloneClosures.sql
the message tells: "..current transaction is aborted..". However, when I
copied the command to a query window to run, it was successful. It is a
polygon feature class with less than 1000 rows.
When I ran
psql -h flash.HaidaMapping.local -d hm -U postgres -f
the same problem occurred.
Any input would be appreciated.
Thanks a lot
John
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081212/86daa3e7/attachment.html>
