[postgis-users] pgsql2shp.exe fails with Windows Vista
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sun Dec 14 13:34:08 PST 2008
Dan Blomberg wrote:
> I have an issue. Using PostGIS 1.3.3 and Windows Vista (business and
> home) each time I go and run the command to export the database to a
> shapefile a popup box immediately comes out and says "pgsql2shp.exe has
> stopped working" and you only have the option to kill the process or
> send an error report then kill it.
> Does anyone have any ideas or solutions?
> Dan
> http://www.gpsfiledepot.com
Hi Dan,
I did a quick search on your error message, and I see some reports that
disabling DEP in Vista resolves the issue. However XP SP2 has this
issue, and I don't see it on my build system - I might need to go and do
some more checks...
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
