[postgis-users] Re: Problem loading shape data (Paul Ramsey)
John Zhang
johnzhang06 at gmail.com
Mon Dec 15 14:09:51 PST 2008
oops............here are the attachments
On Mon, Dec 15, 2008 at 9:58 AM, John Zhang <johnzhang06 at gmail.com> wrote:
> Hi Paul,
> Thank you very much for the input and the hint on how to get the whole
> error message.
> Attached are the error message file and the generated script file for your
> reference.
> The commands used are:
> - shp2pgsql -s 3005 "..\AbaloneClosures.shp" hm_vect.AbaloneClosures2
> > D:\tmp\AbaloneClosures2.sql
> - psql -h flash.HaidaMapping.local -d hm -U postgres -f
> Based on the error message, the table "hm_vect"."abaloneclosures2" seemed
> created. However, it is not.
> Your input on the problem would be much appreciated!
> Thanks
> John
> Date: Sat, 13 Dec 2008 16:36:00 -0800
>> From: "Paul Ramsey" <pramsey at cleverelephant.ca>
>> Subject: Re: [postgis-users] Problem loading shape data
>> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
>> Message-ID:
>> <30fe546d0812131636v212853d8wa3422f29f4e142fc at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> You have to scroll up in the window until you can see what the
>> *actual* error is... increase your command terminal scroll buffers to
>> 5000 then re-run and scroll up to the first error message.
>> On Fri, Dec 12, 2008 at 3:17 PM, John Zhang <johnzhang06 at gmail.com>
>> wrote:
>> > Hi there,
>> > I used shp2pgsql command to convert shape data to postgis. I met a
>> problem
>> > when I tried to run the generated sql data file.
>> > The command is as follows:
>> > shp2pgsql -s 3005 "..\AbaloneClosures.shp" hm_vect.AbaloneClosures >
>> > D:\tmp\AbaloneClosures.sql | psql -h flash.HaidaMapping.local -d hm -U
>> > postgres -f D:\tmp\AbaloneClosures.sql
>> > the message tells: "..current transaction is aborted..". However, when I
>> > copied the command to a query window to run, it was successful. It is a
>> > polygon feature class with less than 1000 rows.
>> > When I ran
>> > the same problem occurred.
>> > Any input would be appreciated.
>> > Thanks a lot
>> > John
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081215/713aac21/attachment.html>
