[postgis-users] Probe_Geometry_Columns()
    Paolo Cavallini
    cavallini at faunalia.it
    Tue Dec 16 06:29:38 PST 2008
Hi all.
 SELECT Probe_Geometry_Columns();
throws an error:
# SELECT ''::varchar as f_table_catalogue, n.nspname::varchar as
f_table_schema, c.relname::varchar as f_table_name, a.attname::varchar
as f_geometry_column, 2 as coord_dimension, trim(both ' =)' from
substr(sridcheck.consrc, strpos(sridcheck.consrc, '=')))::integer as
srid, trim(both ' =)''' from substr(typecheck.consrc,
strpos(typecheck.consrc, '='), strpos(typecheck.consrc, '::')-
strpos(typecheck.consrc, '=') ))::varchar as type FROM pg_class c,
pg_attribute a, pg_type t, pg_namespace n, pg_constraint sridcheck,
pg_constraint typecheck WHERE t.typname = 'geometry' AND a.atttypid =
t.oid AND a.attrelid = c.oid AND c.relnamespace = n.oid AND
sridcheck.connamespace = n.oid AND typecheck.connamespace = n.oid AND
sridcheck.conrelid = c.oid AND sridcheck.consrc LIKE
'(srid('||a.attname||') = %)' AND typecheck.conrelid = c.oid AND
typecheck.consrc LIKE '((geometrytype('||a.attname||') = ''%''::text) OR
(% IS NULL))' AND NOT EXISTS ( SELECT oid FROM geometry_columns gc WHERE
c.relname::varchar = gc.f_table_name AND n.nspname::varchar =
gc.f_table_schema AND a.attname::varchar = gc.f_geometry_column );
ERROR:  invalid input syntax for integer: "(-1"
Apparently it fails when SRID is -1. Any hint?
PostGIS 1.3.3.
All the best.
pc
Paolo Cavallini, see: * http://www.faunalia.it/pc *
