[postgis-users] edges of road - sidewalk of road
Kevin Neufeld kneufeld at refractions.net
Wed Dec 17 08:57:21 PST 2008
Hi Regina,
According to the wiki notes:
"You can suppress linking to old-style references and URIs by preceding the word with a '!', e.g. NotLinkedAsWikiName,
http://not.linked.to/"
I did this here (seems to work):
  http://postgis.refractions.net/support/wiki/index.php?ComputeMultiCentroid
-- Kevin
Obe, Regina wrote:
> That's the problem with the wiki or my inability to use it.  Try
> stripping every where you see ?
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *lisek lichu
> *Sent:* Wednesday, December 17, 2008 6:41 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] edges of road - sidewalk of road
> Thanks,
> I have my geom in table named segments.
> I added upgis_lineshift function to my database and after use
> SELECT upgis_lineshift(the_geom,10) As right_line from segments;
> I get message like this:
> ERROR:  column "st_startpoint" does not exist
> LINE 1: SELECT  ST_Azimuth(ST_StartPoint?( $1 ), ST_EndPoint?( $1 ))
> so I checked:
> select AsText(ST_StartPoint(the_geom)) from segments;
> and I get
>               astext
>  POINT(-8.593025208 41.180818082)
>  POINT(-8.594827652 41.187632944)
>  POINT(-8.591823578 41.193090782)
>  POINT(-8.611950874 41.190119708)
>  POINT(-8.613796234 41.179203081)
>  POINT(-8.602809906 41.180559684)
> (6 rows)
> so ST_StartPoint exists and works well.
> I don't know what is goin on :P
> * The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant
> to Massachusetts law. It is intended solely for the addressee. If you
> received this in error, please contact the sender and delete the
> material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
> postgis-users mailing list
