[postgis-users] Confusing Distance
David William Bitner david.bitner at gmail.com
Wed Dec 17 12:53:29 PST 2008
How did you chose to use 32661?  You should use an SRID that uses a
projection that works well for the area that you are working in.
On Wed, Dec 17, 2008 at 2:34 PM, sub3 <steve at subwest.com> wrote:
> Hi,
> I was trying to calculate the distance (in NM) from two points.  I've found
> a method using distance_spheroid, but I am curious why my original method
> didn't work correctly:
> select distance (
>  transform( GeomFromText('Point(-76.29145663 -45.9229366415 )', 4269),
> 32661),
>  transform( GeomFromText('Point(-76.42922377 -45.2098919078 )', 4269),
> 32661)
> ) / 1852
> gives me 297 NM, but it is really a lot closer.  I thought distance() would
> return the number of meters, then I divide by the number of meters in a NM.
> Thanks for any help.
> http://www.nabble.com/Confusing-Distance-tp21060820p21060820.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081217/bc5cca15/attachment.html>
