[postgis-users] Help with an area and hole filter query?
Paragon Corporation
lr at pcorp.us
Tue Dec 30 17:15:02 PST 2008
Bob,
Are you looking to fill in the holes or just exclude polygons with small
holes and that have small areas.
Anyrate you should take a look at
http://postgis.refractions.net/documentation/manual-svn/ST_NumInteriorRings.
html (will give you number of holes)
ST_InterionRingN
html (will give you the holes)
Then use ST_BuildArea to convert holes to polygons so you can take the
ST_Area of it.
http://postgis.refractions.net/documentation/manual-svn/ST_BuildArea.html
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob and
Deb
Sent: Tuesday, December 30, 2008 5:50 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Help with an area and hole filter query?
Hello PostGIS Users,
I have a polygon table that has many small areas and holes. Now, I would
like to remove small areas and holes that are 2800 m^2.
Any help or advice would be really appreciated.
Thanks in advance.
Bob
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081230/810df088/attachment.html>
