[postgis-users] What SQL admin tools are you using?
Randall, Eric
ERandall at eriecountygov.org
Wed Dec 31 13:31:24 PST 2008
Stefan,
Thanks for the info, I'll definitely give it a try. I mostly use pgAdmin3 and OpenJump but I also use Lightning Admin for PG and MySQL.
http://www.amsoftwaredesign.com/
Not free but cheap when on sale (currently 4.99 for both until tomorrow).
-Eric
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
Stefan Keller
Sent: Wednesday, December 31, 2008 1:13 PM
To: PostGIS Users Discussion
Subject: [postgis-users] What SQL admin tools are you using?
Regaring surveys... I have yet another question:
What PostGIS/PostgreSQL admin tools are you using?
I think up to now there have been three possibilities:
1. GIS built in (GUI)
2. psql (CLI)
3. pgAdminIII (GUI)
Recently I've found a nice alternative to 3. pgAdminIII, called:
4. "SQL Workbench/J" (www.sql-workbench.net).
Stefan
NOTE: Download SQL Workbench/J development build 102.8 (2008-12-31) or
later! In order to display geometry data as text (i.e. as WKT) in
SELECT statements, follow the following instructions (from:
http://www.sql-workbench.net/dev-history.txt > Build 102.8,
31.12.2008)
> Enh: (102.7) for specific datatypes, data retrieval in the DbExplorer can now
> be done by applying expressions to the column when building the SQL
> to select the data.
So, for every DB there are configurations entries in a file called
"workbench.settings" (Windows users look at "C:\Documents and
Settings\<user>\.sqlworkbench\"). There, the following line has to be
inserted:
workbench.db.postgres.selectexpression.geometry=astext(transform(${column},4326))
Now, for SELECT statements in the DbExplorer view of SQL Workbench/J
all column values of type geometry get through this function.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
