[postgis-users] facing problems while loading lwpostgis.sql inPostGIS
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Fri Feb 1 10:58:49 PST 2008
On Fri, 2008-02-01 at 16:38 +0900, Tim Bowden wrote:
> I vaguely recall there was a requirement for postgresql to be run before
> installing postgis. Is this still the case, or have I not correctly
> remembered?
Hi Tim,
As long as PostgreSQL is installed, you can do make/make install to
build PostGIS fine. However PostgreSQL must be running in order to
connect with psql and execute the lwpostgis.sql script.
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
