FW: [postgis-users] facing problems while loading lwpostgis.sqlinPostGIS
Mark Cave-Ayland
mark.cave-ayland at ilande.co.uk
Fri Feb 1 10:55:38 PST 2008
On Fri, 2008-02-01 at 14:49 +0530, ahmadbasha.shaik at wipro.com wrote:
> In this path that you had mentioned
> ./configure --with-pgsql=/usr/local/bin/pg_config
> Are you referring to /usr/local/pgsql/bin/pgs_config because the above
> path does not exist.
Ah yes. Try instead:
./configure --with-pgsql=/usr/local/pgsql/bin/pg_config
ATB,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
