[postgis-users] Re: psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERREUR: Impossible d'accéder au fichier "$libdir/liblwgeom" : No such file or directory
ishikawa
technikos2 at gmail.com
Mon Feb 4 01:32:43 PST 2008
>could not access file "$libdir/liblwgeom": No such file or directory
I had the same error today.
Have you reinstall postgis?
I find something wrong in my postGIS installation.
There seemed no error when
-configure
-make
-make install
But when
-make check
there is fatal error.
psql: FATAL: permission denied to set parameter "lc_messages"
Creating spatial db postgis_reg
createdb: could not connect to database template1: FATAL: permission denied
createlang: could not connect to database postgis_reg: FATAL: permission
Something went wrong (no postgis installed in postgis_reg).
For details, check /tmp/pgis_reg_28654/regress_log
Maybe you failed to install postGIS, too.
---Env-----------------------------------------------
HOST_OS: debian
PostgreSQL version: 7.4.17
PostGIS varsion: 1.3.2
-ishi
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080204/9e5340e6/attachment.html>
