[postgis-users] Shp2pgsql : unable to convert french UTF8encoded shapefiles
Alexandre Gacon alexandre.gacon at masagroup.net
Mon Feb 4 07:40:32 PST 2008
Hi Michael,
I have checked my data and it is UTF8 (the 'é' character is encoded as E9).
The "SHOW client_encoding" return UNICODE as result. The encoding field of
my database displays UTF8.
I join a small shapefile to test with.
I use the following commands
shp2pgsql fra94034______00 teleatlas_2007.testdb -W "UTF-8" > myfile.sql
And
pgsql -d gis_database -f myfile.sql -U postgres.
Sincerelly,
Alexandre Gacon
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] De la part de Michael
Fuhr
Envoyé : lundi 4 février 2008 16:28
À : PostGIS Users Discussion
Objet : Re: [postgis-users] Shp2pgsql : unable to convert french UTF8encoded
shapefiles
On Mon, Feb 04, 2008 at 10:29:17AM +0100, Alexandre Gacon wrote:
> I am trying to load several shapefiles provided by TéléAtlas in a
> postgis database with shp2pgsql on Windows XP and I have several problems.
> The shapefiles contains the data for France and are encoded in UTF8.
Are you certain the data is UTF-8?  Have you verified by looking at a hex
dump?  Might some or all of it be in another encoding?
> If I generates pgsql files without indicating the encoding to use,
> shp2pgsql works fine but I can't execute the file with psql : I got an
> error about an "Illegal byte sequence". If I open a pgsql file with
> the pgAdmin tool, I manage to execute the sql request and it works fine.
What does "SHOW client_encoding" return in pgAdmin?
> This solution helps me but it is not enough : I can't do this for
> large shapefiles (the pgAdmin tool can not open the file) and I have
> several hundreds of files to load.
> If I try to generate the pgsql file with the -W "UTF8" option, I got
> the same error than the psql command : "utf8 : Illegal byte sequence".
Do you have a small shapefile you could make available for others to test
with?  What are the exact shp2pgsql and psql commands you're using?
Michael Fuhr
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080204/532f8c18/attachment.bin>
