[postgis-users] Shp2pgsql : unable to convert french UTF8encoded shapefiles
Paul Ramsey
pramsey at refractions.net
Mon Feb 4 09:26:38 PST 2008
That's ISO 8859-1, not UTF-8
http://en.wikipedia.org/wiki/ISO_8859-1
In UTF-8, é is 0xc3a9
P.
On 4-Feb-08, at 7:40 AM, Alexandre Gacon wrote:
> Hi Michael,
> I have checked my data and it is UTF8 (the 'é' character is encoded
> as E9).
> The "SHOW client_encoding" return UNICODE as result. The encoding
> field of
> my database displays UTF8.
> I join a small shapefile to test with.
> I use the following commands
> shp2pgsql fra94034______00 teleatlas_2007.testdb -W "UTF-8" >
> myfile.sql
> And
> pgsql -d gis_database -f myfile.sql -U postgres.
> Sincerelly,
> Alexandre Gacon
> -----Message d'origine-----
> De : postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] De la part
> de Michael
> Fuhr
> Envoyé : lundi 4 février 2008 16:28
> À : PostGIS Users Discussion
> Objet : Re: [postgis-users] Shp2pgsql : unable to convert french
> UTF8encoded
> shapefiles
> On Mon, Feb 04, 2008 at 10:29:17AM +0100, Alexandre Gacon wrote:
>> I am trying to load several shapefiles provided by TéléAtlas in a
>> postgis database with shp2pgsql on Windows XP and I have several
>> problems.
>> The shapefiles contains the data for France and are encoded in UTF8.
> Are you certain the data is UTF-8? Have you verified by looking at
> a hex
> dump? Might some or all of it be in another encoding?
>> If I generates pgsql files without indicating the encoding to use,
>> shp2pgsql works fine but I can't execute the file with psql : I
>> got an
>> error about an "Illegal byte sequence". If I open a pgsql file with
>> the pgAdmin tool, I manage to execute the sql request and it works
>> fine.
> What does "SHOW client_encoding" return in pgAdmin?
>> This solution helps me but it is not enough : I can't do this for
>> large shapefiles (the pgAdmin tool can not open the file) and I have
>> several hundreds of files to load.
>> If I try to generate the pgsql file with the -W "UTF8" option, I got
>> the same error than the psql command : "utf8 : Illegal byte
>> sequence".
> Do you have a small shapefile you could make available for others
> to test
> with? What are the exact shp2pgsql and psql commands you're using?
> Michael Fuhr
> postgis-users mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-
> users<94034______.zip>_______________________________________________
