[postgis-users] multiline to linestring
Dane Springmeyer
blake at hailmail.net
Wed Feb 6 08:07:15 PST 2008
Gustavo,
I'm not exactly clear on how you want to use ST_Dump, but I'll give a
shot a some example SQL that might help...
> I want to convert linestrings from multilinestrings, with
> linemerge, to obtain united linestrings in overlapping points
> with this sentence:
In your subject you say "multiline to linestring" however.
From the astext output below it seems you are saying that you
started with multilinestrings and they didn't change after your
query. Is that right?
> "MULTILINESTRING((4.8938679245283 46.3443396226415,33.313679245283
> 73.7028301886792,49.5872641509434 80.0707547169811,90.9583136792453
> 89.2813679245283,54.3363797169811 103.03608490566,29.0620872641509
> 103.293985849057,12.2125589622641 107.1625,11.1624233831055
> 106.590266209164,10.4214805264064 107.529010012923,11.2220067193803
> 108.417488521584,12.2326314413493 107.778056025276),
> (37.506947728971 97.6302534161404,12.1756482134062 82.9892270906306))"
> with numgeometries=2, the logic result with my original data.
> How can i extract those linestrings separately?
if you want to work with each multilinestring separately then I think
you'll want to turn them into two linestrings in two rows.
This works for me:
--create that test data
create table ml_string (id serial,the_geom geometry);
insert into ml_string (the_geom) values (geomfromtext('MULTILINESTRING
108.417488521584,12.2326314413493 107.778056025276),(37.506947728971
97.6302534161404,12.1756482134062 82.9892270906306))',-1))
--check it as WKT
select astext(the_geom) from ml_string;
select g as id, ST_Dump(ST_GeometryN(the_geom,g)) from ml_string,
generate_series(1,(Select ST_NumGeometries (the_geom) from
ml_string)) as g;
--which is the nearly the same as directly calling ST_Dump on your
multilinestring:
select ST_Dump(the_geom) from ml_string;
Sorry if I am off track. Just send another note with clarification if
you can...
Dane
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080206/607f1fae/attachment.html>
