[postgis-users] multiline to linestring
Gustavo Ces
g.ces at pettra.es
Wed Feb 6 08:59:21 PST 2008
Thanks for answering, Dane!
Reading my post you can see i don´t see clearly what i´m doing. ;)
What i want to do is to create a unique linestring from other linestrings, some of them sharing points. When line 1 and line 2 have both a common point, then i want a unique line as result. And when they don´t share a point, then two lines. So i was reading old list archives and i read about linemerge.
But linemerge seems to produce that multilinestring, and what i want are two linestrings. So i try to dump the multilinestring and then errors appear...
1) St_dump doesn´t exist as function, and i don´t know why ( maybe an old postgis version?).In Postgis manual:
"Availability: PostGIS 1.0.0RC1. Requires PostgreSQL 7.3 or higher." so, which is the problem?
2) if i try to dump(linemerge(collect(the_geom))) then :
ERROR: set-valued function called in context that cannot accept a set
Estado SQL:0A000
But if i try your sentence it works well, so the problem appears when you try to dump(linemerge(collect.... directly.
Which is the difference?
It works with your example but don´t know why... :(
Gus
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080206/35711881/attachment.html>
