[postgis-users] Re: if i use postgis, is it true that i'll then have to worry about supporting only 1 database??
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Feb 8 09:57:00 PST 2008
Right, that's Direct Connect, but in my opinion that is still SDE in
between ..... though not in the form of an application server.
Best regards,
Bart
Paul Ramsey schreef:
> Indeed, it looks like there was a form of low-level time support that
> must have been built in the academic research days... it only survived
> into the 6.X series:
> http://www.postgresql.org/docs/6.3/static/c0503.htm
> As the page notes, you can do historical information storage with
> triggers pretty easily.  This is distinct, however, from "versioning"
> as understood by ESRI, which is a form of branch-and-merge operation.
> P.
> On 8-Feb-08, at 8:55 AM, Chris Hermansen wrote:
>> Postgres (not PostgreSQL) had a kind of versioning built-in; it was
>> called "time travel".
>> I believe that time travel was supported at one time in PostgreSQL, too,
>> and there is some contributed stuff laying about in the PostgreSQL
>> install that would indicate it's still do-able.
>> dnrg wrote:
>>>> In order to do this, you may need some interchange
>>>> software developed - for instance, if you have to do
>>>> any "traditional cartography", how will you proceed?
>>>> By converting your data to shapefile and then using
>>>> ArcView?  How will you maintain / update your
>>>> data?  Using QGIS, or will you have to buy say some
>>>> kind of plugin software component for Arc*** so that
>>>> you can edit the PostGIS spatial data?
>>> ESRI tells me that, at the ArcGIS Desktop release 9.3,
>>> you'll be able to edit PostGIS data as core
>>> functionality. No SDE required. This will open doors
>>> and minds I hope. Paul, any comments on that?
>>> At ArcGIS Desktop 9.2, evidently, you can already edit
>>> PostGIS data using the Interoperability extension.
>>> Paul, will PostGIS ever have versioning functionality
>>> for editing workflows similar to ArcSDE? Guess that
>>> would pervert the data, and then PostGIS would "own"
>>> the data in a way like ArcSDE does presently. Still,
>>> many shops find versioning valuable for workflows.
>>> Not sure how I feel about versioning. Just curious how
>>> PostGIS developers feel about it--if it's in the
>>> development roadmap / pipeline or not. And if not, why
>>> not.
>>> Dana
>>> ____________________________________________________________________________________
>>> Be a better friend, newshound, and
>>> know-it-all with Yahoo! Mobile.  Try it now.
>>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Regards,
>> Chris Hermansen · mailto:clh at timberline.ca
>> tel:+1.604.714.2878 · fax:+1.604.733.0631
>> Timberline Natural Resource Group · http://www.timberline.ca
>> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
>> C'est ma façon de parler.
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
