[postgis-users] Adding a new GEOS call to PostGIS
Brian Hamlin
maplabs at light42.com
Fri Feb 8 22:21:51 PST 2008
It recently came up in the IRC channel FreeNode #postgis
that there is a GEOS TopologyPreserveSimplify, in addition
to Simplify2D.
I did a bit of checking just now.. on my machine, I see
nm /usr/local/pgsql/lib/liblwgeom.1.3.so
_LWGEOM_simplify2d
_pg_finfo_LWGEOM_simplify2d
_simplify2d_lwgeom
and some others, but no TopologyPreserve anything
nm /usr/lcoal/lib/libgeos_c.1.4.1.dylib
_GEOSSimplify
_GEOSTopologyPreserveSimplify
and lastly, in lwpostgis.sql
CREATE OR REPLACE FUNCTION simplify(geometry, float8)
RETURNS geometry
AS '$libdir/liblwgeom', 'LWGEOM_simplify2d'
LANGUAGE 'C' IMMUTABLE STRICT;
since the last SQL line matches the exported symbol name from liblwgeom
exactly, minus the front _, looks like there is the exact entry point.
Clearly no parallel entry for TopologyPreseveSimplify
this makes me think that there is a little more to adding the call to
lwpostgis.sql than copying and pasting the declaration.
insights welcome
-Brian
